Bruce Bump
Forum Owner-Moderator
Today I heated it up to about 2100f and fluxed it to keep oxidation to a minimum and began flattening it slowly. It naturally developed high spots at the angles that Needed to be ground off. The main thing is to have it an even thickness otherwise the pattern is altered. Just continued to heat and slowly flatten, grinding away the thick spots as needed until it was flattened completely.
I drew the tang out some but this blade is longer than I need so I will shorten the bar and re-draw a tang later.
I began to form a tip on the anvil being careful to retain my basket weave. Its easy to form a tip by drawing and shaping but that would string out the pattern so I hammered it down and ground away the thickness on both sides several times. This should keep my basket weave pattern. I dont have a picture of what this is to look like so right now its generic shaped. Time to draw a plan and cut off the tang and forge some more later.
