Ok I took it up to 2300 F today, maybe a bit more, and I'm pretty sure it will go more if I let it.
I started with the blower at about 3/4ths damped and ended up with it full open. I started the gas at about 2 psi. You can actually hear the gas valve whining over the roar of the forge in I think the first video. Not sure on the second video where I had raised the pressure to about 2.5 PSI. The valve stops whining somewhere around 2.5 PSI.
drive.google.com
In this video I had opened the damper to about 1/2 way as the temperature climb had started to level off at about 1650 F or so.
In the second and final video I have the damper fully open and the gas up to about 2.5 PSI and when I shut it down at just over 2300 F it was still climbing.
drive.google.com
I closed the bricks up quite a bit as my shop temp quickly went up about 105 F. I'll need some better ventilation, and maybe a fire suit to work in front of this forge! I most definitely will not be forging in my shop during the worst part of the Arizona summer. It is pretty hot standing in front of the forge even at about 5 feet. 2-3 feet and hair starts singeing. While taking the videos my phone gave me an over temp warning!
I took some surrounding temperatures, and the steel floor (sandwiched with 1" layer of cementitious board) below the forge only got to about 130 F, the underside of that shelf was about 85 F which is just above the propane. But the cementitious board above the forge was like 330 F. And the plywood on the top that is sandwiched with the 1" cementitious board was about 130 F as well. Seems a bit hot. As I have some more cementitious board scraps I'll probably stick another layer on the bottom of that shelf. If that doesn't bring the temp down to something reasonable I'll replace the plywood with sheet metal.
I'll let it cool down, do a quick inspection and fire it up again this afternoon.
I didn't see any cold spots, I'm a pretty happy guy!
