I did the ITC coating today. Pretty sure there are areas that have more than they should have but the top and sides of my forge refractory are so craggy it tends to collect in the crevices. It is what it is. The floor is about the only thing with a nice even coating. At this point I'm thinking I'll wait till Sunday to fire it up again just to give all the excess time to dry properly.
Then I discovered the back blast from the forge was melting things that weren't even that close to it. For instance the plastic shield on my bench grinder!
I had noticed that there was a lot of heat escaping the back so I had stuck a bit of scrap 1/8" plate behind the fire bricks.....It took a bit of heat...the 1/8" plate is definitely scrap now!....
So though I was going to build my tong's holder next but I decided the build the removable plug for the rear of the forge to control the back blast....
Kao wool rigidized...
cover....
in position...(though not mounted, not totally sure how I'm going to mount it yet)
And then some piddly stuff
I finished up the extra layer of cement board insulation on the under side of the top shelf. Note the hi-temp RTV isn't there to seal anything (though it really looks messy!) but rather to hold up the cement board..... The RTV is supposedly good for intermittent temps of 650 F and the highest I have measured at that point was about 300-330 F.....
And while I had the RTV tube open I put a dab on the ceramic insulator for the T/C to hold it in place..... The ceramic tube keeps trying to slide into the forge....
That was my day! Tomorrow I should get my gas system parts and I'll try to get my tong holder rack built.
