The joys of living in a HOA {g}, and in an urban area. While I'm in an urban area, I'm isolated enough I can do outside forging just fine. My forging doesn't make as much noise as shooting the old 45-70 does.
The coating over the koawood should be fully cured (as it is by end of day before applying the ITC-100. Remember to go light on each coat allowing a tad of drying between coats. From my reading slow curing of the ITC-100 isn't as critical as is the castable covering the kaowool. It seems firing the ITC-100 with small increments of heat as you've did with the castable.
If this isn't correct, please Ed chime in and keep both of us on correct path.
