Dennis Morland
Mike - Cranking up the forge always warms up the shop on a cold day.
Dennis, when you full grind like this, do you ever have the problem of forming a "drop/plunge line" at the spine? I have had that problem and was wondering whether anyone else had issues with this too. ThanksI was going to heat treat last night. But, I got into a grinding groove and just rough ground them all. I will heat treat tomorrow. Started with 12 blanks. Screwed up one and ended up with 11.
I have also heard from a reliable source it can be fixed with careful work on a contact wheel if you do not have a surface grinder. Of course, I have never ground too far on a knife personally.Although it can be fixed with a quick trip to the surface grinder.
Alright thanks! I'm guessing you could use a disc sander or pretty much anything to restablish a flat.Alden - If I understand your question correctly, do I get a bit overaggressive on the grind and leave a plungeline at the spine? Simple answer - Yes. I have done that several times before. Usually when I am trying to do to many things at once or I get in a hurry when grinding. I hate doing this! Although it can be fixed with a quick trip to the surface grinder.
Well done, Dennis!Took me most of the night. Heat treated and tempered (x1). 5 knives on the left will have a hamon. 6 on the right will just be shiny.
Randy.... what is that blue material? Obviously something synthetic..... but not familiar with it....but I like it! Particular the flow of the patterning.I have this one in progress. Still have some sanding and polishing to do but I’ll finish it up tomorrow.
It's an old scrap of blue jeans he tied around the handle, Randy is just real good at his finish work...Randy.... what is that blue material? Obviously something synthetic..... but not familiar with it....but I like it! Particular the flow of the patterning.
