Bruce Bump
Forum Owner-Moderator
Bruce are you making your springs, or do you buy them? If so, I'm curious how they're designated. Is a spring's strength dependent on the wire gauge and diameter? Or some other factor? I'm just curious, not urgent. Have a great day!
This spring is from a gunsmith friend of mine and is just an educated guess at whether it will work for this gun. I have wound my own springs on a custom turned mandrel in my lathe and may need to make one for this application. The machinery handbook has a chart that gives mandrel sizes for all wire gauges to arrive at a given diameter.
Another genious friend of mine bought every wire size available on ebay and gave me some of each if I need to make one. The wire diameter and the distance between the coils determines the spring rate. Given the same wire diameter, the wider the spacing between the coils, the stronger spring rate.
