i occurred to me that i never actually tested any of the knives i finished, so i took the chance of this knife that didnt pass the appearance test. if i remember correctly i took the edge to .5mm, then old 120g belt on platen, 400g on slack between idler wheel and platen then strop and nothing more
thats from 6mm leaf spring btw
it shaved hair with almost no pressure, then cut paracord, then folded paracord 8, cut through it with just slight pressure. then did that to a piece of 1x2 (its what i had at the moment and i stopped because my arm hurt (yes i know i know))
then decided to try on that 1cm diameter wire, that needed either lean with my body weight, swing blade or hack, even after that it removed hair with almost no pressure
THEN i decided to go cuckoo on soda can, it did cut through but not so smoothly ( i have nothing else to compare to really) abd still removed hair but had to apply considerable pressure!
now i will have to resharpen with my new, and just in time, spyderco tri-angle
btw if you guys have any test methods let me know, i did intend to take that to destruction
