Frank...speaking of simplicity...your website is beautiful! Nice job! That is similar to what I am having my son build.Ted, I like #1. I like the simplicity but I'm biased due to my etching difficulties. I just changed to a stamp which presents its own issues.
Thanks. We did not originally intend it to look like mountains. Then realized it did and even discussed a "peak" going over the H and working jags down toward the right. The line through Montana then represents the prairie.I rather liked the squiggles on style #3. Kinda sorta reminds one of mountains on the horizon. Do agree that taking "Made in" off the second line makes it cleaner.
I had the stencil touching the light bulb...and didn't realize it for about 30 seconds....Like I say...what i did was crude but I know it can be fine tuned. The inkjet print was done in best mode and was flawless looking...much finer than the stencil resolution. The whole thing needs to be fiddled with...the results i got with very little effort gives me a good sense that It will be easy to tune the process.Ted, what did you use to print with - laser or inkjet? My concern about printing direct to stencil material is washing the laser toner (or inkjet ink) off. While the toner/ink would keep the emulsion from water soluble under the pattern, and that's all it needs. You can see in the left side of the "H" where there is still emulsion that's not clearly washed off, and in the "K" and "E" of "knife" it looks like part of the emulsion is washed away in part of the letters. Also the "e" in "Hauser" has the hole in the e looking like most of the emulsion is washed away - it should be dark red like rest of template. As long as there's enough emulsion to prevent etchant from leaking thru it'll be fine. As far as the 110 lines - if the threads in the fabric allows etchant to soak thru good, they most likely will not show up in the etch.
It will be interesting to see the etch once your power supply gets there. Got a 12vdc battery? Try that {g}
Ken H>
Ted, since the inkjet ink will wash off, then printing direct to the stencil material is a great idea! I don't think a laser printer would work so good - the heat from laser would be too much for the emulsion, and the toner wouldn't wash off after exposure. As Kevin says "I want to see it on a blade!"
Ken
I don't know why my scanner works so lousy....these turned out lush. I decided to use all the cad work to make cards so that the continuity is good.(same as the makers mark) I'll have one of the boys take a pic...anyway I got a lot of knife projects done today....Thanks Ted. It took me a bit to figure it outFrank...speaking of simplicity...your website is beautiful! Nice job! That is similar to what I am having my son build.
It’s pretty clear now who’s the boss of the Hauser operation. Lol.My etcher did not come in so I did this instead....View attachment 62119I don't know why my scanner works so lousy....these turned out lush. I decided to use all the cad work to make cards so that the continuity is good.(same as the makers mark) I'll have one of the boys take a pic...anyway I got a lot of knife projects done today....
Ted, what CAD program do you use for the cad work? I use Draftsight a good bit, but am starting to look at CamBam for CNC work.
Etcher unit showed up today....grubby...used...and not working.![]()
