That looks good....brass is almost double the conductivity of steel...but only about a third of aluminum. Still...much better than steel...and the personalizers use steel.I made mine out of a Brass screw, piece of 3/8" thick Brass guard material and a plastic handle from a garden shovel I cut off. Figured since I was going to use salt water as an etching solution and most Sea worthy boats use either Brass or SS for fittings due to the salt water (plus I had it) it would work fine? Still have to put etcher all together but I have most of what I need just need to find the right size tool box to enclose it all.
View attachment 62131 View attachment 62132
The conductor plate is normally made from either brass or copper - not sure you'll ever know any difference in etching. Yes, copper has more conductivity, but brass doesn't really have that much resistance either so it will work just fine.
Ted - got the sample today, starting to work on making a stencil this afternoon.
I couldn't either....till after I printed on the wrong side...The emulsion is thicker on one side of the mesh than the other (as you have noticed)I've got a sample sitting in the sunlight now - leaving it for 10 minutes to see how it works. I've got a brush ready to rub emulsion away. Boy, is it hard to tell shiny side from dull side! Not at all sure I can tell the difference between dull 'n shiny side.
