Bruce McLeish
Practice , Practice , Practice !
Me too. excellent work BjmacI am super impressed my file work was never that good.
Thanks ,Daniel, for the comment. Now get started on yours !That guard is really nice! I really have got to get started on mine. I’m pumped for it!
It will actually go from either direction. It's going to be attached with a brass pin through the tang and then epoxy. And thanks for the compliment.Ok. Help out a noob here. Does that guard slide on from the top or bottom?? And how is it attached? And nice design by the way!!!
Thanks Chris. This particular effort was (and still is) requiring alot of effort , but I believe part of the kith project is to give it your best shot. After all , some other knifemaker is gonna get this and I don't want to be embarrassed !You have more patience than I will ever have. I would have done a frame handle and been done with it. Congratulations for pulling it off...
Are the pins going in from the front, parallel to the blade and into the scales on either side? Seem like Dennis Moreland did something similar on his hidden tang bowie.It will actually go from either direction. It's going to be attached with a brass pin through the tang and then epoxy. And thanks for the compliment.
You are correct sir. About being embarrassed...I do not think so... you made the whole project with FILES...You will have nothing to be ashamed about I know how hard that is and I never tried anything to the level of that knife with files only.but I believe part of the kith project is to give it your best shot. After all , some other knifemaker is gonna get this and I don't want to be embarrassed !
I was just ponderin that very question, The brass is .090 and the pin hole would be .062. too tight of a tolerance for this ol boy ! your quote of Dennis's method sounds SOOOOO much easier and better. I believe that I will go that route. Thanks for the tip.Are the pins going in from the front, parallel to the blade and into the scales on either side? Seem like Dennis Moreland did something similar on his hidden tang bowie.
Thanks CHRIS ....That's an awfully nice thing to say...but ya ain't seen the finished product, either! There are just sooo many ways to screw this up. and I seem intent on finding them all!You are correct sir. About being embarrassed...I do not think so... you made the whole project with FILES...You will have nothing to be ashamed about I know how hard that is and I never tried anything to the level of that knife with files only.
Thanks , Jason.The only reason I asked how you got the guard was because I don't know if I every seen a Full guard on full tang knife before. Anyway that pretty cool how you did that.
