bladegrinder
19 ? holy mackerel ! I'll say that should keep you busy....Ha ha !
A little final hand sanding and a little polishing on this handle before I get started on the sheath.![]()
I got the profiling done on some more stainless blades that the holes need drilled and the flats cleaned up...once these are ready for heat treat I think that will make 19 that I will send out to peters which should keep me busy for a long tim.
Then I have a large hunter Im working on that will sport Bocote scales and a hand rubbed finish.![]()
Beautiful! Do you dye each piece of leather to get that cool banding look?
Ty...That is absolutely lovely!! Good job!
Tonight's work... Sanding everything nice and flat on the granite slab. Right now everything is at a dirty 400 grit. If everything goes well I'll start etching tomorrow night to bring out the hamon.
that really turned out nice. Is that a Scandi grind all the way to the edge, or is there a tiny secondary bevel there at the edge?
looks good!
Wouldn't every scandi grind have a tiny bevel from sharpening or is a scandi brought to sharp by the grind itself? AND....is every scandi a hollow grind or straight grind? I have only been doing flat/straight grinds so pardon my ignorance.
Agreed. A scandi that is effectively a zero grind may be traditional, but they are a pain to sharpen without trashing the looks of the finish. A good beater knife with a scandi grind is easy to sharpen- you don't need to care about angles since you lay the flat on the stone and go to town. But to get the bevel looking good again is a mighty task. A tiny secondary bevel never hurt anybody.
