Kevin Zito
Dude that's beautiful. Will 5160 hamon like this
I've always referred to it as jimping
And you are right in doing so
Sent from my iPad using Tapatalk
5160 is a deep hardening steel, if you do an edge quench you can get a little line, but for active hamons with lots of detail use shallow hardening steels such as 1075, 1084, 1095 and W2Dude that's beautiful. Will 5160 hamon like this
Sent from my SM-N915V using Tapatalk
Gotcha! Thanks! I'm holding a piece of 1095 (compliments of my bro DeMo) in my hands as I type. I'm gonna make a simple skinner, with hamon (lol... prob will be a disaster). I'm focusing on simplicity and fit and finish. Please, guys, let me know if the hamon is too much for me at this time. Will post pics as they come.
I wouldn't say it's too much....we all gotta start somewhere. That being said, creating/exposing a hamon can be tricky at times...if it doesn't work out this time, use it as a learning experience and keep trying. It took me several blades before I figured out all the techniques I needed to achieve a good hamon. I still don't turn out a lot of them, because of the "give-n-take" factors.
Remember: Google is your best friend.
Hamon tutorials that helped me.
http://ryanwknives.blogspot.com/2013/01/my-personal-hamon-process.html
http://imageevent.com/paleoaleo/hamonbladetutorial
Carry on!
DeMo
Hmmm... MS says tricky... KZ says bye bye. You know, someone once told me that guards can be tricky. I didn't listen, oh, but I listen now. DeMo, thanks for the links. I'm gonna research it more before I make the call 100%. I use google, but I trust you all, and I've found some junk on the internet before. That being said, I'm getting better at sifting. Thanks guys as always.
Ed said "tricky" not "impossible". Granted some makers are able to get more out of a hamon. John Doyle comes to mind. Don Hanson creates a nice hamon. So does Burt Foster.
You are more than capable of getting a hamon created. It just may need some refinement to be perfected. And to get perfected, you need to practice.
If you feel up to it, give it a shot. Just like the guard, you can overcome this obstacle.
DeMo
Dennis, you know I'm more than likely gonna try it lol. But fitting that guard taught me everything I needed to know about life haha. By the way, is CRA 1095 the same as 1095. Thanks! Ty sorry for hijacking.
CRA = Cold, rolled. annealed. It is 1095 that has been cold, rolled and annealed.
just a little clarification.... "Cold rolled" is material that got it's final shape at the mill from being squeezed between rollers. "Hot rolled" is done the same way except it is done at high temp. It has less stress in the material than cold rolled but will have scale that can be a bit hard. "Cold Rolled" anything is best if it is "stress relieved" before working with. Stress relieving is heating up the material enough to "relax" all the internal stress caused by rolling.The stress will move the material as you cut/grind/machine. I do not know how the different knife steels are prepped...I'm relaying info from many years of machining various steels. the worst for movement seemed always to be cold rolled 1018...which is a real mild steel.
Hope this helps....
I think I may be talking about a swedge???
Was off today so I took some time for knifemaking.
Folder Im working on and some fixed blades I got pre heat treat grinds done on.![]()
The gimping is on the spine for traction with your thumb. I also think you are referring to the swedge.
