Oops, forgot to post a couple again!
4" Magnacut drop point with orange AmeraGrip handle scales with thick, vintage natural micarta liners. Customer has big hands, so I made the handle a bit chonkier for his hands!
I did a different method for the jimping on this one. I used a side cutting bit in the Dremel to cut them so the bottoms would be rounded. I marked out the spine before cutting into it, but next time, I will use the Cricut and the stencil I used for the electro etching to make it easier to keep the gaps even.
It's just over 3/8" scales and the liners were .070 IIRC? This is before the oil was put on the handle and the orange stays nice and bright!
I've been wanting to do a handrub flat/high polish satin blade bevel for a while, but I struggled getting my grinds dead even to have a flat below the spine to do this with. They usually ended up full flat grinds, so this is my first high flat! Finally got one I was happy with! This is a 3/32" thick magnacut blade, cutting portion of the edge is just over 3", 3.5" tip to handle.
Handle material and guard is a G10 (black, brown, black and tan IIRC)/Copper Laminate from Current Composite. They usually do these laminates where it has a maze pattern on the outer facing side of the block, but this time, they flipped it so the maze patterning is on the side/ends of the scales. One side is awesome, but the other side was more regular just with how the material was folded and pressed.
It is a bit heavier than G10 weight wise, but the copper didn't give any issues heating up or anything, but I worked it slow. It had a black g10 frame.
I grabbed this pic from Currents FB page. You can see a larger chunk of this material at the bottom of the pic and see the folded/ripple pattern on the side of the piece. The blueish piece and red/white/blue pieces standing up is how they normally do it and I really want to get more! They also do it with aluminum as well.
A quick video of it:
I buffed the handle as well and it still has nice grip to it, but youtube downgrades the video quality a bit.
I started this 1/4" thick 80CRV2 blade a while back, so I decided to finish it off! Around 6.75" cutting edge, vintage natural canvas micarta handle, hollow stainless pins and stainless lanyard tube. I did a flat grind and then convexed it, but kept some of the flat below the spine. The convex softened the bevel line, which I was OK with. Still need to sharpen and decide if I am going to straighten the clip out a bit or not and do a sheath for it.
