What are your favorite blade steels? Why?
H
horizonod
Guest
Crucible is in BK. Anybody have any idea how that's going to effect availability of their blade steel??
Anybody know where a guy might pick up a few sheets of CM154 or CPM154
pocomoonskyeyes
I'm not a maker, just a user. For me throw away the stainless and give me HC,any Hc steel that is done right. I take care of my blades so stainlessness is of no import to me, I'm not in a corrosive environment so there is no need for stainless. If I do want a stainless it is for a "wallhanger" as long as it is polished up, I don't care what kind of edge it holds, It's an ornament. Never had one as good as HC steel. O-1, W-2, 1095, 5160 D-2 you get the idea. Just do it like it should be done according to it's type/classification.
C
CAD
Guest
CPM154 and S30V....just call me a stainless type of guy!! :
Chris D. :D
B
Brutus
Guest
VG10 is my favorite, I'd say. It sharpens very well, and holds an edge for a good, long time. Also, it's used on the knives that I'd say are my favorites.
FLymon
Member
If I had to choose just one I would have to flip a coin between 1095 and 154CM.
I like a thin 1095 blade for a little whittlin', and 154CM gets real sharp while being very tough, and pretty stain resistant.
T
tonester
Guest
right now i am really loving the SR-77 on my SOD. i can chop a small tree down with it and the edge stays nice and sharp. with a little sand paper and a strop i can get it back to shaving sharp in no time.
i also really like 1095 and O-1, just because most of my blades are made of this and i know how to take care of them and sharpen them.
B
bikerdoc
Guest
Novice, rookie amatuer that I am I only have worked with the carbon steels. Mostly 1095. Going to try 01 and D2 soon.
For production knives S30V is good
I hate VG 10, Just me I guess
For other steel I find it all depends on the geometry and heat treat.
A well intentioned relative gifted me a chinese 440C no name when I had my operation, suprisingly it has stood up and is my "saturday knife" for all those anoying honey dew list chores.
M
monkeyboy
Guest
L6, heat treated properly will cut all day, take all sorts of abuse and stay together.
i hear CPM3V is super steel??
buzz
M
Mr. Knife Guy
Guest
I don't have much experience making knives with a lot of different steels, I have only been making knives for a little over a year. But since this is in the production knives section, I assume that the question was aimed more at using knives, instead of making them. I use production knives a on a reguar basis, everyday. Sometimes only for opening an envelope, sometimes for chopping down small trees and pretty much everything in between. I use S30V, ATS-34, 154CM, AUS-8A, 440C, 420HC, VG-10 and probably a couple more. To be completely honest, I can't really tell much difference between any of them. One may stay sharp a bit longer than another, but other than that, there is not much difference at all. As long as they have a good heat treat, they all work quite well. I sharpen my knives VERY often, I like to keep them sharp rather than let them get really dull and have to put a new edge on them. I don't think that there are really any bad production steels these days, except for maybe the mystery alloy on the Frost Cutlery knives that you can buy for a dollar.
commodorewheeler
As a user, my favorite blade material is Stellite 6K, even though it is not technically a steel. It's virtually corrosion proof, it holds an edge great due to its high wear resistance, it's non-magnetic, and it is inherently very slippery, which makes it cut through stuff with less drag and easier to clean than steel is.
It is softer and not as tough as steel, but under normal use, I've never had any problems with it at all.
B
Big Mike
Guest
I’m not prejudice, …I like them all. :bud:
But I generally favor the tool steels.
I know that edge geometry and heat treatment are just as important as steel type,
…and find that knives made by proven makers will perform well regardless of the metallurgy.
:running dog:
That said I like Mike Stewart’s convex A2 in my woods knives and have come to love the edge holding of Bob Dozier’s D2 in my hunting knives.
Another steel that has impressed me is the W1 I have in a forged blade from Stephen Fowler, it quickly takes a wicked edge and hold it quite well.
T
tu tone tommy
Guest
I work with both 1095 & 01. I like Carbon Steel. I built a knife out of D2 once & sent it to D'Holder To heat treat for me. That was the only D2 so far I have worked with but like it. As for production knives ATS 34 for stainless, & I really like Case's CV. I care a mini Copperlock in that steel & love the sharp edge. Surprising it hold pretty well for a carbon steel. But I also keep my knives tuned up on a regular basis.
Antonio_Luiz
Active Member
As a user and not a maker I find that it is the sum total of all the parts working in harmony that is important. Focussing just on the steel used without taking everything else into consideration is not all that meaningful. A knife in D2 by DBK will be very different from a Bob D. but both use steels of the same name. I use a variety of cutting tools (not just knives) and my favourite steel is whatever I can afford that works best at the application it's designed for. I have a preference for zone hardened and/or laminated blades and in most applications I find it's one of the high carbon steels rather than a stainless that works best for me but not always.
James Terrio
I agree that geometry is the biggest factor, followed by accepting that proper HT is essential, followed by choosing an alloy that gives what you want in terms of edge-holding, toughness, corrosion-resistance etc. A well-ground blade of Home-Depot "welding steel" will out-cut a clunky obtuse blade made from the newest super-steel. Not for long, but it will.
All factors being equal, 420HC? No thanks. I agree that Buck makes the most of it, with keen geometry and high-quality HT. It's actually pretty decent at resisting corrosion and reasonably easy to sharpen. For many many people who field-dress one deer a year, a Buck 110 for $30 is a great choice. But never forget that mass-production facilities choose alloys like 420HC, AUS6/8 etc because they are cheap, easy to stamp out in vast quantities, and machine very easily. NOT because they're truly superior performers.
All you folder makers, please offer your favorite models with carbon steel blades. I can't tell you how many times I've read posts and articles from folks who love carbon steel, want a light, handy folder, and can't find one with O1 or 1095 blade(s).
SCALPHUNTER
For "hand forged" blades=1095 Carbon Steel, and for "production" blades=ATS-34. Both steels hold a good edge and are easily resharpened when needed.
Motor City Mike
I'm really liking S35VN. IMO it holds an edge as good as S30v but is easier to sharpen and is less prone to chipping.
Also CTS-XHP is very nice too.
HHH Knives
Super Moderator
Damascus of course. 1095 and 15n20 is my preferred combination. it hardens great and takes a great edge. its easy to resharpen when needed. It etches great.. 440C is the go to stainless choice.. And as stated O1 is exceptional blade steel and in my top 3
Frstr8
Designated Dog Photo Chopper
Not a knife maker, but I like 154's and was VERY impressed with the CTS-XHP. I would really like to have a folder made with the CTS.
James Terrio
A few days ago I tested a thin (1/8" stock) blade I made of CPM-154 at Rc59 (GP-4 model, seen in my avatar, link to the test results in my sig line). I expected it to keep a good edge and already knew it took a very nice finish. I didn't expect it to cut/chop and then dig/pry through a 2x4 with ZERO chipping or bending of the edge or tip. This was meant to be a destruction test but the knife is still in excellent shape after a slight touch-up honing. Yes, you can break such a blade if you clamp the first 1/2" in a vise and crank on it, and throw the un-handled blade flat on a concrete floor as hard as you can. I know because I did just that with a blade with the same grind and HT as the one in the link. I did not shoot it out of a cannon or try to chop through cinder blocks with it :D
I will definitely continue to use CPM-154. Frankly I think its toughness and durability is underrated. I also look forward to working with similar, newer steels like Carpenter's XHP and Crucible's S35VN, they sure look good on paper.
