Pattern/template
opaul
I may try a folder shortly. Any of you guys have a template or recommend a place where I can get plans to try this phase of knife building?
Thanks!
Bruce McLeish
If you want to do a slip joint then I would order one of USAknifemaler's slip joint kits and use it as a template. I did. Other than that I would holler at John Wilson he makes killer folders, but don't tell him I said so...
Or, you can just holler at him for no good reason...he's used to getting hollered at!
MTBob
Thanks!
I'm about in the same position, slipjoints / folders are my next mountains to climb.
If you didn't see this posting a few days ago, it has a number of references for slipjoints, including Don Robinson's book. https://knifedogs.com/threads/new-to-folders-slip-joint-template-resource.49674/ That posting and Don's book seem to be excellent sources of slipjoint construction. I also purchased Steve Culver's book "Slip-Joint Folder Design and Building". It kinda overlaps with Don's book, but also seems like good information.
I'll be anxious to see your work as it progresses.
IanF
Thanks!
What kind of folder are you thinking? Locking or non-locking, any preferance?
Chris Railey
Probably non-locking to begin with but depends on level of complexity.?
Friction folders are about as easy as a folding knife gets. If you want to start there I posted a rough how to on those a couple of years ago. I still make them from time to time because I like them.
Gliden07
I bought a cheap friction folder on Amazon to copy. I actually wasn't expecting much for around $13, I liked it so much I never took it apart and made a molded sheath for it! I carry it most days!! LOL!!
pewel018
New Member
After paying some dollars and getting cheap type of knife makes uncool and unreliable for me, Best way to develop and use reliable.
