OPauls Knife Picture Thread
I counterbored and epoxied an antler plug to hide the retention nut and screw
Your craftsmanship is superb, what an eye for style and detail!
Did you place a nut on the tang and then attached the antler piece on with a screw, or is it the reverse of that?
Thank you very much. I drilled a hole in the end of the tang and then cut a slot to insert a #6 bolt. Then counter sink and attach the antler with a washer and a nut I like doing it this way because I can get good clamping pressure and line up.
