Thanks for all the positive feedback, I got my basic adjustable work rest done today and wired up a few things in the shop(switches for the heat treat oven and welder), I went to take some more pictures and the camera was dead! I will get some pictures of the platen design with some measurements this week end so you guys can get a better idea. Also, I filled ALL the voids in the grinders structure(all the tube steel) with polystyrene foam board and then capped em off with great stuff spray insulation(everywhere I didnt need to have access to a bolt for maintenance), then I put the same 1.5" thick foam board insulation under my work bench using spray adhesive, then used some thick rubber under my motors mounting feet, this cut WAY down on the vibration. Then I noticed something BAD... one of my pillow blocks on the grinders primary shaft has a bad crack in it, must have happened during installation(I had to help the pillow blocks onto the shaft with a mallet... prob had something to do with it, lol, this is causing some vibration when I am running at the 2 higher speeds, I will be replacing that ASAP, Ill get those pics up by Sunday. Thanks again guys.
