Steven Kelly
Forum Owner & Moderator
Nice tutorial Bruce...
Thanks for the tips!!
Another trick it to use a mirror on the flat of the guard so the reflection of the handle is visible in the mirror. If the handle is straight it will show up in the mirror. The mirror trick was taught at Josh's hammer-in by Tim Hancock. It works great for squaring a guard to the blade too.
Bruce, I don't get how to use of a mirror to check for straight handle/blade and to check for a square guard.
Mike
Thanks for the effort of putting this together, Bruce.
I'll be adding it to my Favorites.
Only Hidden Tang I've ever done was a Bark River Settler, and the handle was a 2 piece.
I do have my Smoke Jumper to do, but that, too, will be 2 piece.
Here's the Settler. I wanted there to be more handle to it.
That was also my first attempt at making a guard.
Bruce - Great tutorial! Thank you for making it look so very simple.
Two Questions:
1) I've been making hidden tang knives almost exclusively and have learned a few of the procedures you show by trial and error. The process you show that I am not able to mimic is milling out the tang slot in the guard. I have no milling capabilities, so I use small files to do the job. I'm getting better, but I still have much room for improvement.
Other than going slow and careful with the files, what tricks have you up your sleeve that might help me get a better/tighter fit from this process?
2) Other than using a ruler to check the straightness of the handle glue-up, what tricks do you have for making sure the blade is square and parallel with the handle block? I often end up with my blade turned a little ****-eyed in the block and that throws off the whole process for there.
Thanks again Bruce.
Bruce
One thing that kinda intrigues me or maybe i missed something
when you dremel the guard??
is there a trick to making it fit with the handle?? err does that make sense?
Bruce,
I cant find the debonder your using on the finish.
Would acetone or alcohol also work as a substitute?
/QUOTE]![]()
Bruce, been scouring through the archives to get hidden tang construction set into to my brain. Found an old tutorial you put up, which is great by the way.
I got a pattern drawn out, a couple handle material choices, some SS for a guard and spacers,etc. But, could you please tell me what you are using for the black spacers on this knife? You called it "fiber" washers, but not sure what you're using. I'd really like to try and replicate the look of this guard, if you don't mind, at least as close as I can.
/QUOTE]![]()
Anthony, its called vulcanized spacer material
I copied this link from here on Bosses site http://usaknifemaker.com/spacer-liner-black.html
