Frustration!
J. ROSA
When was the last time you guys were frustrated with something you were working on and why? I have had my first sword back from HT for a while and while I was working on it the motor on my grinder took a dump on me. I have a 2HP that I had stored but I'm renting my space and it isn't equiped with 220V. I wired it to 110V but I know on start up it is drawing over 20 amps because I keep blowing the 20 amp fuses in my switch. I'm not sure I want to take out the fuse in my switch and try to run it with that much current since I'm unfamiliar with the age of the wiring. I know it could be done but..... My landlord was cool enough to look for a new breaker and said he would help me see if we could wire in the 220V. That was a week before Christmas which seems like forever now. I have no idea when he'll be able to help me and I really don't have the cash to grab another motor right away:mad: To add to the frustration I just saw a post from someone making a sword with some of the ideas I had been planning on for about a year. Can't blame that one on the motor.....
So it looks like I'll be hand sanding this thing until it's done. When was the last time you were frustrated?
Here's a pic of my never ending project in motion....
Doug Lester
Does taking a blade back out to the forge to straighten it and then grinding the fire scale off and discovering that it now has a 1/2" crack in the edge count?
Doug Lester
Patrick
I just replaced a motor on my 14" bandsaw that crapped out right before my very first show. It was free on craigslist.org but i had to drive 100+ miles to get the new motor. This happened after my HF horizontal metal cutting bandsaw won't accept 64.5" blades. They have to be special orderd. It's been a while since I used it. The new blades should arrive in another week. If you're not getting frustrated you aren't doing it right.
Pat
Sean Cochran
Frustration is what keeps us humble. Ive got a pile of scrap steel in my shop and at one time every piece started as a knife. I was frustrated every time I screwed one up, but on everyone of them I learned what doesn't work.
Just last week I screwed up a customer's knife just because I was in a hurry. Lesson learned: by rushing I have caused the knife to take twice the time it should have.
You just have to learn to look at every mistake or SNAFU from a positive angle. Maybe as you are hand sanding you will discover a new technique(sp.?) that will help you in the future.
Sean
Jake Mello
I have been trying to complete four small hunters for a new model. The first three I got to finishing up the shaping of the handles, when I came back the next day the liners split. So I cut out new handles epoxied those to the liners, then they split. At this point I think the cold has something to do with it so I make and epoxie some more handles, but bring they home to keep from getting cold. It seems to work. So I proceed to move on to shealths. Well Get them shaped and they hold to tight so I modified them and they don't hold at all. So I thow them away. And it happens on the next ones. AHHHHHH!!!!! Keep in mind it is taking me four weeks to get only two of the four knives done. Now I am on the last two, and I still can't get the sheaths to work right. I have never been so frustrated with a knife before. But it only drives me to find a way to make them work. Even if it means not selling one for another couple of weeks.
Jake
T
torqueman
Guest
I'm on my first blade. Ya I know a little frustration. About every few minutes going from that is looking pretty good to well I just screwed up that grind line.
C Craft
The best thing for frustration is to get it all out. The next time something like that happens pick up a big hammer and give it a fling.
Oh, make sure the that the neighbor or his dern cat is not in the way. Well the cat's OK as long as the neighbor don't see!!!!!!!!!!!:eek::D
I can feel your pain brother! I have been building a KMG clone and at last count I think I have broken three or four taps and one is still in the piece of steel but that is still cheaper than a big ticket item like a motor!!!
Sometimes you just got to smile to keep from crying! :)
