Thanks Brad. Still got a ways to go on it but I think the bulk of the heavy lifting is behind me now... no pun intended
I picked up 5 gallons of hydraulic oil today so I could pre-lube the ways with it before reinstalling the saddle. This way I'm not sliding on dry ways before my fresh oil makes it through the system.
Getting it lined back up. It took a little fiddling with to get it in the right spot but I didn't skin my fresh paint too bad.
Back home with the levers, knobs, and handwheels back on
This is how the troff that got the electrolysis looks now
Ready to drain the tank. I've got a plastic under the bed storage container handy just in case I have trouble getting the plug back in. I didn't need it though and had no problem draining it one paint tray at a time
1st look inside the tank with the access door removed
With the drain plug pulled there is still about an inch of sludge in the bottom. I started scooping it out with a little putty knife but that was for the birds. I figured I give my bucket head vac a try a sucking the sludge out and it actually worked fantastic.
After vaccuming out the bulk of the sludge there was still quite a bit left to go so I made up this little sludge rake to scrape what was left up to the opening so I could get it with the vac
Filters removed and scraped clean
The filters are just steel mesh wrapped around a frame so they could be cleaned out for re-use. I gave them a half hearted cleaning so I could inspect them.
There's a couple places where the screen is pulled loose from the framework and this big tear in one so I don't want to rely on these for filtration. I think I'm going to eliminate these and covert to an external screw on filter.
Parting shot for the night
-Josh
