DeMo 2022 Kith
Dennis Morland
I took John’s advice and hit the grinder. I cleaned off all the decarb. I then hand sanded the crap out of the blade. Then into the etch for 3 rounds at 10 minutes each.
This is why I like the KITH. I learned something today. Grind the decarb off before giving up on the hamon. I will polish and the blade should get even nicer.
Flip side.
Sean Jones
Flip side.
Looking good!
Dennis Morland
It is time to polish. I want to see exactly what is in their for a hamon.
I use these two products. Flitz. Not because it is anymore special that any other polish. Again, I can get it locally at Menards.
I made these little wooden applicators. They have felt attached. The felt is a non skid chair/table pad. Just cut to size, peel the paper and attach. Pretty darn simple.
After first step about 10 minutes of rubbing your n each side. I use the black Flitz first. It is more watery than the tube. The tube is a paste and will be used later. It will take several attempts to get the blank polished to where I want to get it.
Dennis Morland
When I first started making knives 10 years ago, I purchased a deceased makers inventory. Included was 2 bars of brass. 4 feet long, 2 inches wide, 1/4 thick. Perfect for bolsters.
After this set, I have 30 inches left from the original 96 inches. Here is the kicker, original price was $6 per foot. I wish I could find some more at that price.
Just cut of a length that is needed.
Split it, and you have both sides.
Dennis Morland
Time to get the bolsters attached. I start by rounding the front. Where the bolsters meet the blade.
Next, I scallop the back. Where the handle meets the bolster.
Then I rough the top of the bolsters. Just enough to making sanding/shaping much easier.
Dennis Morland
I hit each hole from the outside with a 3 degree tapered reamer.
Here makers will differ. I epoxy my bolsters to the blade. Some makers do not. My reasoning is to keep moisture from going under the bolster. So I partially drill holes on the bottom side of the bolster to allow the epoxy to pool in the indentions.
Should look kind of like this…
