Sean Jones
When I worked in IT naming conventions were a big thing. Thus I decided to name this thread the way I did to avoid confusion. Since there may be a number of similar WIP's for the KITH I thought this might help. Just a suggestion for sure. But I think it might help with clarity.
Any rate I have been working on a design for my Bowie. I'm planning on using AEB-L and send it out for heat treat. While my heat treat process is getting better I'm not entirely comfortable with it as yet. Plus my new forge is also a WIP. Too many projects as usual.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here is my proposed design. Overall length is about 11 1/2 inches with a 6 1/2 in distal taper blade. The handle to the back of the Ricasso is right at 5 inches. Which may be a touch long. Unsure about that at this point. AEB-L is 5/32" from Alpha Knife Supply. Handle material will be Claro Walnut. 416 Stainless fittings and probably Corby Bolts as it will be a full tapered tang. I'm unsure about spacers. I have both Blue and Red .060 G10. I'm thinking the Red would have the best contrast. We'll see.
Still a lot to think about. Though I'm planning on getting the profile cut out this week and sent out for heat treat sometime next week. That is unless some one points out a glaring error...which is certainly possible![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![69413 69413](https://knifedogs.com/data/attachments/50/50297-899d00cd4274416d473cb0e773c85d51.jpg)
