Wrought iron pipehawk
Robert Mayo
I just finished this one for a client it is 18 1/2" overall with a 5" head from bit to the top of the bowl and a 2" edge.
Thanks for looking and your comments.
Cheers Bob
N.D.
Very Sweet!
Did you burn the hole all the way through it W a red hot rod or drill it?
Robert Mayo
Very Sweet!
Thanks for the comments folks!
N.D. i wish i could tell you that i burned it through with a red hot rod but i buy my hafts with the hole already drilled through.
Bob
N.D.
Bob
Well Lookout Mr. cause here come the questions!!!
So . . ah . . I guess that means some one else makes those beautifully delicious grained wood hafts, right . . care to share the name W us? Hmmmm?...
Regardless, it works for you, the head looks awesome too!
How do you make a useful cutting tool from Wrought iron, I always thought that it wouldn't work well for that?
Robert Mayo
Ok Mark i will start with the last question first it's closest:p.
If you look at the photo you can see the dark part where the edge or bitt is, this is a piece of 1080 forge welded in the center of the two ends of the wrought iron which gives you a hardenable edge.
Not at all i found the source of these hafts on the forums by info shared by others they are expensive but my clients deserve nothing but the best:rolleyes:.
http://www.dunlapwoodcrafts.com/
They are not listed on there website but just ph. and ask.
Cheers Bob
N.D.
Cheers Bob
:DThanks, that is very sweet work; I just have 1 more new question for you, Who's Mark?:p :bud:
