Smallshop
16 in. Long Reach Pliers Set, 2-Piece
Amazing deals on this 2Pc 16In Long Reach Pliers Set at Harbor Freight. Quality tools & low prices.
I use these. Stripped most the plastic off the shanks...
I take all the plastic off of them and forge the handles (reins) out straight. In my opinion, plastic doesn't really have a place on any of my forging tools.![]()
Amazing deals on this 2Pc 16In Long Reach Pliers Set at Harbor Freight. Quality tools & low prices.www.harborfreight.com
I have a similar set, I guess I will get to try a few different things![]()
No problemo. (Or where you referring to Smallshop's link? We linked to the same thing...)I just looked at those Long Reach Pliers - those would be so easy to make tongs from. Perhaps even cutting the tip off and welding a new shape to fit the tongs you wish. For the oven work those are just fine. I think I'll get a set for my oven rather than the blacksmith tongs I normally use. Thanks for linking those., I've got them added to my "List" in HF.
I was actually referring to both of ya'll. I agree with your method of making tongs, that's how I did it. I've got 3 pair I made from horse nippers (used for trimming horse hoofs for shoeing) I ordered from ebay several years ago. A real deal, 3 pair for $15 to $20 shipped, not much more than $5 each. My last pair I build from scratch - used a tad smaller rod for the reins than needed, but they work just fine.(Or where you referring to Smallshop's link? We linked to the same thing...)
We'll see what I can do with some propane or I can pick up a can of Mapp. I really don't want to waste oxygen on them if I don't have to. Especially since I only have the small OA rig.I was actually referring to both of ya'll. I agree with your method of making tongs, that's how I did it. I've got 3 pair I made from horse nippers (used for trimming horse hoofs for shoeing) I ordered from ebay several years ago. A real deal, 3 pair for $15 to $20 shipped, not much more than $5 each. My last pair I build from scratch - used a tad smaller rod for the reins than needed, but they work just fine.
I know you said you don't plan on getting into forging, but I bet you would benefit from a small coal or propane forge.We'll see what I can do with some propane or I can pick up a can of Mapp. I really don't want to waste oxygen on them if I don't have to. Especially since I only have the small OA rig.
Does that put you in Pennsylvania?I know you said you don't plan on getting into forging, but I bet you would benefit from a small coal or propane forge.
My forge is a hybrid. It's an old Champion coal forge and I use anthracite coal as the primary fuel, but I also have propane plumbed into the tuyere (Google Tuyere to know what I'm talking about). It serves two purposes - it use it to light the coal and I can also use it on it's own (in conjunction with the blower) sort of like an inverted propane forge.
ANYWAY, I've found anthracite coal to be a lot... like, a LOT more economical than a propane torch.
I haven't used MAPP in a while. Ya see, it's illegal to make MAPP gas now (not new news - it has been for years). The new MAP-Pro is not the same. All it is, is a blend of Propylene and Propane.... you can buy cylinders of straight propylene. As far as I'm concerned, MAP-Pro is a RIPOFF!
I agree - the temp difference between propane and mapp isn't anywhere near worth the price. I do get conflicting info, from one site I read: "MAP-Pro gas burns at a temperature of 3,730 degrees Fahrenheit, while propane burns at 3,600 F. " note only 100F difference. While a different site says: "3,450 degrees F for propane".As far as I'm concerned, MAP-Pro is a RIPOFF!
Same experience. I never noticed a difference between MAPpro and propane. If I wanted to get more BTU out of my MAPP/propane torch, I'll just go to the welding supplier and buy a cylinder of proplylene.I agree - the temp difference between propane and mapp isn't anywhere near worth the price. I do get conflicting info, from one site I read: "MAP-Pro gas burns at a temperature of 3,730 degrees Fahrenheit, while propane burns at 3,600 F. " note only 100F difference. While a different site says: "3,450 degrees F for propane".
An even different site also says 3700F for Mapp gas, but that "it doesn’t affect the flavor of the meals it is used to sear."
I purchased a bottle of mapp gas for my torch and really never noticed any real difference between mapp and propane in actual use.
Will a propane (or mapp) torch get the ends of the needle nose pliers in question hot enough to bending? Either one "might" work.
Virginia. Little east of Richmond.Does that put you in Pennsylvania?
I was unaware that MAPP was gone. I guess the real question is "is propane" sufficient for bending or whatever it is I have to do to the tongs?
I grew up in NE PA and of course, I constantly heard about Anthracite Coal. Used to go to the state park and pick up chucks of it the size of bowling balls off of the ground. Cool stuff. There were plenty of homes still burning it when I was growing up, and they would put out the ash cans on the streets for pickup. They would use it on the snow/ice for traction, but if you fell into it on your sled or whatever it was like a pit of razor blades.Virginia. Little east of Richmond.
I grew up in NE PA and of course, I constantly heard about Anthracite Coal. Used to go to the state park and pick up chucks of it the size of bowling balls off of the ground. Cool stuff. There were plenty of homes still burning it when I was growing up, and they would put out the ash cans on the streets for pickup. They would use it on the snow/ice for traction, but if you fell into it on your sled or whatever it was like a pit of razor blades.Good times...
Yeah, well that clinker was all over our roads as of first snow. So if you were sledding hills you would eventually hit it. It would slice you up but good!By the way, the razorblades you're referring to are "clinker". When you burn coal, you end up with ash and clinker. It's all the non-flamable stuff that's left over. It's melts into clumps. Hard and brittle.
Ya know, I bet that would hurt!
When I was younger, me and some of my friends went sledding on a huge hill. My buddy hit some hard packed snow and veered off into a briar patch.
Now, these aren't like rose bush thornes. These briars are huge. I'm talking 1-1/2" thorns.
Not sure where I was going with that story... good times.
