Couple of things:
Someone mentioned it earlier, but you definitely want to let your oven soak (empty) for a while before you start heat treating. I have a home built oven that normally gets up to temp in about 30 minutes or so, but I like to let it soak empty for 45 minutes to an hour (after reaching temp) before adding my steel. I've noticed the temperature fluctuation stabilizes pretty significantly after soaking.
As far as checking oven temps, a good sanity check is simply to dip your oven's TC into a cup full ice water. That is, fill a cup full of ice and cold water, stir, and let sit for a couple of minutes. Stir it again, and drop your TC in. It should read 0C/32F. If it reads a little higher or lower, then there's a chance that you need to calibrate.
