C Craft
I have some questions about the uses of the different leather weights when it comes to making sheaths.
I about to make an order from http://www.wickett-craig.com/index.php/leathers/description-and-grading
So this is from their Overstock page, http://www.wickett-craig.com/index.php/leathers/description-and-grading
What I am thinking of doing is ordering as follows:
1 ea. Harness 11-13 oz Tan Special $123.00 per side (this one is to be spit to a 7-8oz, leaving a 4/5oz. which I will take also)
1 ea. English Bridle 8-10oz Tan Special $135.00 per side
In essence this will leave me the following:
1 ea. 4/5 oz. for thin leather needs
1 ea. 7/8 oz. for use smaller knife sheaths
1 ea.8/10 oz. for use with larger knives and for backing
Does that sound about right for the weight verses the use?
Also I assume that when they split a hide and you tell them you want both splits, that is considered two hides you are purchasing???
One other thing that concerns me about the Bridle and Harness leather, is this says the color is Tan, so I assume that means it is not the natural color of the Carving/Tooling grade. Rather it means it has been dyed! Can it be re-dyed without a problem?
This is the following description of their Carving/Tooling:
Our tooling leather is used by the best leather crafters in the world. The natural color is super for any color dye you want to use. It has the same great carving and tooling ability as the skirting. We stock this in 8-10oz and we will custom split it to any weight you want, free of charge. Check out our “color” and “pricing” tabs for more information.
My problem with it is that it is not thick enough to split and end up with a useable grade of leather, that is why I am thinking the Harness and Bridle might be the better choice! Any insight that anyone can share with me on this subject will help make my order easier and less stressful!:biggrin:
