Don Robinson
Here is what I do for pivot screws. I use an 8-32 pivot screw and I put a nylon insert in it to stop it from turning. Make a jig block with 8-32 threads tapped in it. Drill a hole for a #51 drill perpendicular to the threads so that it will allow you to drill a hole 3 threads from the end of your pivot screw. Remove the screw after drilling the hole in it and deburr both sides of the hole. Take a piece of weed eater line that measures .165" in diameter and force it into the hole. It should slide in easy. Trim both sides flush with the threads with a razor. Now screw the pivot screw with the nylon line in it back into the screw jig. This will force the nylon tight into the hole and it will also clean up the ends. Now just screw it into the pivot of your folder and it will stay where you tighten it.
Thanks for that, Tom.2thumbs
