Does wonders for improving 440-C and ATS 34.
Stan
Bit the bullet and got a 20L dewar.
I'm looking forward to getting it filled and doing some LN cryo!
BC
Maybe this one will work: http://cgi.ebay.com/DEWARS-12-STAIN...in_0?hash=item1c048d1284&_trksid=p3286.c0.m14
Could one not make a vessel with two steel pipe pieces of different size? Weld bottoms onto the pieces of pipe, make 1 pipe one inch larger diameter, insert smaller pipe into larger, make a ring to fit both and weld together. drill hole and solder/braze in a piece of pipe like 1/4" copper water pipe long enough that you can attach a vacuum pump and crimp it off when the vacuum is attained. Draw vacuum and crimp pipe.
Figure 2 in this paper: the cryogenic treatment of tool steels Seems to suggest that leaving D2 in the cryo for longer than 38 minutes causes a reduction in hardness.
Something to think about is that most of the places that have liquid Nitrogen for sale wont sell it if it's not going in an appropriate container. The stuff is dangerous if the right precautions aren't taken. Just ask them Aggies what happens when you don't use the right equipment for storing Liquid Nitrogen.
Just off the top of my head I would think that as liquid nitrogen warms up and reverts from a liquid state to a gas that it would be nitrogen. It's been a long time since I took chemistry so it should be understandable that I might have a problem understanding this, but how does liquid nitrogen convert to CO2?
