Knife Scribe
Discussion in 'WIPs and Tutorials' started by zzknives, Jun 4, 2010.
  1. zzknives
    zzknives Well-Known Member
    hey dogs
    made a knife scribe
    more or less like the one from Tracey
    steel bar
    carbide point
    screw
    crossbow arrow
    couple drills and a small tap
    [​IMG]
    Uploaded with ImageShack.us
  2. murphda2
    murphda2 Super Moderator and KD Blade Show Boss
    That looks like it will do the trick. Nice enginuity.
  3. LR Adkins
    LR Adkins Well-Known Member
    That will work, good job. I like seeing people make their own tools.
    Larry
  4. zzknives
    Thanks
    But not perfect because I can´t just take the point out and replace it
    Hammer it in LOL
    BUT I can´t get spare points here anyway so no big deal *haha*
    Had to take a scriber apart to get the point out
    At least it didn´t cost me much.
    Arrow..don´t know broke it a while ago LOL
    Steel...a few cents
    Screw..a few cents
    But you need a drill press, vise,... otherwise tough to make
  5. graveyard
    graveyard Well-Known Member
    thank new to the making knifes and hobbyest need these stuff me to
  6. ARCustomKnives
    ARCustomKnives Well-Known Member
    You might considering getting a steel rod the same size as the arrow shaft and drilling it out the same size as the carbide point. You can then drill and tap the top end of the rod, and use a set screw to hold the scribe point in place.
    I used the cut off from a partially threaded bolt (cut the bolt head off and the threads), but you can typically get some cold rolled rod at your local hardware for fairly cheap.
  7. cappaletti
    cappaletti Well-Known Member
    nice job..and a good idea..saved u some bucks!
  8. HELLGAP
    HELLGAP Dealer - Purveyor
    good Idea Ive been looking at buying a digital height scale and they run a couple hundred and up . This type of set up will be just fine for scribing .Til now ive been ruining my calipers. thanks kellyw
  9. BRad704
    BRad704 Well-Known Member
    Since you (or we) aren't typically scribing the edge of a hardened piece, would it work to use a hardened piece of steel as the scribe point? It certainly opens up your options...
  10. ARCustomKnives
    As long as the steel is harder than what you're scribing, there shouldn't be a problem. Vernier calipers (typically hardened stainless) for instance are often used to scribe metal/knife blades as well.
  11. James Terrio
    James Terrio Well-Known Member
    Right, you don't really have to get deep into the steel, just scratch through your layout dye or sharpie or whatever.
Share This Page
