backtines
So I finally jumped in and I think it came out ok for the first time..
I bought a 20ton press from Harbor Freight for about 200 bucks . I stuck a 20ton piston in there , I used an old 3/4 hp motor I had as well as an old hydro tank and pump I had laying around. .I piped in a valve and did what I had to do to make this press work..
For sure I will need to beef this thing up . I just wanted to see if it would work.. Im happy to see that it did but definitely will need some beefing up , or Ill just build another one heavier and stronger all around when I have a chance..
Anyway , I took some1084 and some 15n20 , stacked it , pressed it , restacked a few times .. I cut some grooves and drilled a few holes in it and this is what came out of it ..
Im gonna scrap this one . I just wanted to see if i could do it ..
I learned that the i shouldnt rush the pressing .. I need to make sure my pieces are cleaned real good before I stack .. As you can see in the last pic I didnt get a good weld .. I was definitely rushing everything because I wanted to see the result ..
I need to slow down and not be so ancious, but Ill get there .. Im pretty happy for the results anyway ..
I also didnt heat treat this blade .. Im going to do that also just to see what happens.
Thanks for looking and if anyone has a plan on building a good strong press , I would love to see them .
Thanks
I finally finished the knife.. The pics above was a quick profile but I ended up reshaping and getting rid of the bad weld . It's been heat treated and now I can call it done.. This is what I came up with. Thanks for looking..
[/URL]
[/URL]
[/URL]
[/URL]
Thanks
