Gliden07
Thanks Ed! I'm gonna keep plugging away till its done. Then see what happens. I plan on using the info we discussed on the burner placement as close as I can as I split the bricks in 2  and the center would be right on the brick seam. I plan on getting a 1 1/4" Set Screw EMT connector and burning the Galvanized coating off or if I can get my sand blaster to work, the inside diameter should give me the ability to point the burner where it needs to go? Again this is all a educated guess from reading online things and suggestions from people in the know.
