Agreed, it's gonna be a bear to compress. Not only a lack of leverage but it's going to be far back from the front of the work bench and hard to reach.Hmmmm. I'd like to hear other people's thoughts on that hidden spring.
If it has enough spring tension to make the belt track, it's going to be a bear to compress it by just pushing down on the post. It really needs a pivot arm so you can get some leverage on it. Keep in mind your arm is going to fully extended out in front of you when you're trying to push down on it. Maybe I'm wrong.
why not just ad another post on the back with an arm to compress the spring for changing belts![]()
Sent from my SM-G935T using Tapatalk
