Daniel Macina
It’s used to make boat hulls that will see a thousand times more stress and fatigue than any knife handle will ever experience. Fiberglass boats from the 60s (especially sailboats) still fill every marina in the developed world. And that’s 1960s resin when it was a new concept and nobody knew anything about it. I have cut holes in 1960s hulls that are every bit as solid as a brand new hull. Where you see hull problems are with air bubbles and poor bonding to core materials. (Most hulls are a sandwich.) But properly laid glass from 50 years ago is still bonded to wooden structural members like the day it was laid.
GFlex 650 is on a whole new level from that. It is a toughened epoxy that will actually flex under shock loads instead of fracturing. When I see sailboats rounding the capes in unimaginable weather I don’t lose sleep over my knife skinning a deer or chopping cucumbers. If I did worry I’d use corby bolts instead of pins and go back to sleep.
I’ve made mistakes on a couple handles where I got in a rush and put the liners on out of order. Of course I didn’t notice until the handle was cured and I had shaped it, which meant I had to take off the handle and redo it. Nothing I did would make the G-Flex let go. I boiled the knife. I froze the knife. Nothing. I realized I would have to destroy the handle so I decided to see what it would take. I drilled out the pins. I beat the handle with a hammer. I chucked the blade in a vise and grabbed the scales with my biggest channel-lock pliars and tried to break the scales off. All it did was chew up the wood.
I finally took the knife to the grinder. What I found was that the scales, liners, and tang were basically fused into a mono-block. I had to grind the tang back to bare metal because even the streaky remnants of the fiber liner couldn’t be scraped off.
Now, granted this was a newly handled knife. As to the epoxy breaking down over time, I refer back to boat hulls. Can epoxy break down? Yes it can. Most of the time it’s due to UV light damage to cheaper polyester resin. True epoxy is a different animal than polyester resin and the price reflects that difference. Are all epoxies the same? No. But a lot of the difference goes back to being a fast-cure versus a slow cure formula, too.
Boss made a key point. Surface prep is probably the biggest factor. You find that to be true in boatyards everywhere. Bad fiberglass jobs fail regardless of the type of resin. Epoxy bonds via chemical reaction. Residue, bad mix, too much squeeze out leaving the epoxy too thin- all of these things change the reaction.
Thank you sir! I figured as much but figured there was no harm in asking
