Chris623
Now that is a carving knife. You will be proud to cut yourself with a knife like that. Well done.
Thank you, Sir. Bandaids are a carver's best friend!
I've had an issue when cleaning the ricasso area with acetone and a Qtip it dissolves too much epoxy and leaves a small valley under the scale. What's the best way to clean that area?
Super glue also works (loctite 401) as do butterfly strips.Thank you, Sir. Bandaids are a carver's best friend!
That is very nice. Great job.Okay, Gentlemen, let me introduce my first wood carving knife................"Ebony & Ivory". It's actually a lot purdier than the picture, but I wasn't going to put together all my lighting equipment for a quick shot like this one. I've been at it a long time and I'm tired of messing with it. Since I'm not selling it, I probably won't take a better picture, but this one will give you an idea how it turned out. Not happy with the brown reflection on the blade and the brass, but that's what you get when you don't set up all your soft lights and tents, etc.
I feel like I should correct you, here. But... nah, you’re right, I’m just and old seasoned pro trying to help out beginners. Hehe.Thanks. I appreciate the accolades from you experienced knife makers.
Am I approaching this wrong? Am I using the wrong Epoxy.
Does anyone know the hold life on West systems epoxy can’t find it if they have it listed?
That means that you have AT LEAST 50 years before it STARTS to chemically break down.So if it has a 50 year hold life does that mean that the handle will need replaced in 50 years?
I've never seen it listed. The way I found out was calling and talking to the "tech dept". I was told "The minimum hold life on any of our products is 20 years".Does anyone know the hold life on West systems epoxy can’t find it if they have it listed?
I doubt anything will "fly apart". What I found when all the problems came tumbling down on me, is that the epoxy started turning into a powder, and the handles slowly loosened over time....some much worse than others.....but it cost me a LOT of time repairing/replacing things, and a LOT of heartache, trying to make it up to customers.Now I'm worried my knives will come flying apart because I used 5-minute epoxy from Menards
