Canister Damascus
KenH
PACKAGE IS HERE!!!! Now to unpack and see what it's all about
fitzo
I can tell from those casters what the cart you have is like. Strong. We recently bought several 6 foot tall wire shelving units of the same stuff, and those were the upgraded casters. Nice stuff, bears a lot of weight and moves well.
I'm excited to see/read of this press in action for you.
I got stink eye from Missus Normally Enabler fitzo when I started jawing, "You know, I could move one of those in and out of the garage...," and that's as far as I got. "And who is going to hammer out blades?" "Fine."
Yeap, I know those days are gone but an old boy can still dream, nay? Have fun. It's a great journey, thrilling at times, frustrating at times, and always, always something new to learn. Have a blast, sir!
KenH
OK, here's the press setup on the cart. That cart works MUCH better than I was expecting when I opened the box. It's rated at 1,000 lb but I don't see how. The posts are 1" diameter, while a similar cart I purchased from Sam's has 1-1/2" posts, and the wire of the shelfs are all the same size. It does NEED a decent flat plate bolted to the wire shelf for the press to bolt to.
Remember I was concerned about ability to get press into backyard where the anvil is setup with my work tables? Not a problem - little more hassle to roll press out than is the forge, but not a real problem. Here they are setup with forge heating up.
Here's an old truck axle I had laying around, it's about an inch diameter. This is one press with the drawing die. I think it would have pinched it into had I tried. While it won't do what a 25 ton press does, I think it's going to be ok for what I want.
Sorry, no videos yet - got to get some help to make videos. It takes both hands to run the press. So far I'm doing ok with the hand control rather than foot control. We'll see how it goes as time goes by.
fitzo
I'm impressed with that squish. You're gonna ruin some stuff with that, just like the rest of us. Enjoy your journey!
That is a nice-looking forge, too. Is that blower variable speed or gated?
KenH
The blower is has the normal gate over the blower inlet, but I've also got a variable speed control that works pretty good. Just never use it since I'm not trying to use forge in the lower temp ranges. Mostly only in forging temp of 1800 to 2,000F, and welding of 2100F to 2200F range. Sometimes pushing 2250F range with SS San Mai
Here's a better view of that rod showing how thin it squished with one press. Yea, I'm gonna need some kisser blocks {g}
fitzo
Isn't that what the press is for?
I thought about beveling dies. My problem is stamina. I can't hold a hammer any more. 3-4 blows driving 20penny through a 2x4 and the hammer literally falls out of my hand. And it's hard to imagine doing forge work without needing hammer work. :(
Just an old man, dreaming of regaining things lost. I still won't totally rule it out, though. Gotta hope, nay? :)
Chris Railey
I told you it had more power than one thinks. Since you mounted it down acting how far is it from the bottom die to the ground? I am thinking about getting that cart.
KenH
Top of the bottom die is 34" from the floor with the table set at highest level on cart. The top shelf can be set lower as needed.
