billyO
That's why they're considered capital....but certainly no where near covering any of my "capital investments" on tools.
Yep, that's what I understand. I've got a bar of 5/16" X 1-1/2" mild steel (1018 I think) to cut the 5" base from. I've also got two pieces of mild steel that's 1"X3"X5" (left over from a project a few yrs ago) I'll use to make a longer flattening die with. Also plan to have a set of squaring dies made by the time the press gets here which looks like should be here by end of April.It should come with Drawing and flattening dies too. Mine did.
Cool man I am happy for you. Get ready to become addicted to making your own Damascus. Canister or layered. San-Mai, Go-Mai no problem with the press (although I can still do it with a hammer). You can make you own hammers and Hardy tools much easier too.Yep, that's what I understand. I've got a bar of 5/16" X 1-1/2" mild steel (1018 I think) to cut the 5" base from. I've also got two pieces of mild steel that's 1"X3"X5" (left over from a project a few yrs ago) I'll use to make a longer flattening die with. Also plan to have a set of squaring dies made by the time the press gets here which looks like should be here by end of April.
Ken H>
Man. Ken. Can't say I'd let that go 2 seconds without placing an order for it.......... The wife has been pushing me to order the press so I can make her more San Mai and Damascus blades.
Ken H>
Good forging weather if you have a covered forge. I am happy for you, I think you will like it.AND weather is showing 80% rain this weekend!
I guess that depends, but I use the anvil on every blade and almost every billet at least for straightening things.how much is an anvil used when forging with the press?
Looks like Chris beat me, but I do use it frequently when using the press to straighten out the billet when needed. I guess that could be done with the flat dies on the press, but a lot of times it's just easier to whack the billet with a hammer rather than switch out the dies. Even with a quick change die system.Is that anvil use during use of hydraulic press?
I don't see any reason why it couldn't be. The design looks like all the stress would be from the billet outCoal Iron says the press can be mounted either way. Comments?
That's sorta what I've been thinking also. I've seen them mounted with ram at bottom but just doesn't seem natural to me. I'll be trying it as shown in the cart photo.you'll have to constantly adjust your wrist angle,
FedEx is showing scheduled delivery TOMORROW!!! April 22nd.
The more I've thought about it the more I think I need to rig a way to use the press at my normal forging area. There I've got a nice steel work table with a really nice 6" vise (over 50 lb for sure), anvil, and it's where my welders are setup to use. I'm thinking perhaps even if it's a bit of hassle to move outside it would be best. I could leave press outside covered with a tarp when not in uses for a few days at a time, then back inside for longer term storage.
For ya'll who've not seen the cart I'm talking about, Coal Iron says it's rated at a 1,000 lb and 5" wheels. Total weight will be 140 + 120 + 4 gal oil making total weight almost 300 lb with dies etc added in. To me that seems a lot for that cart, but we'll see.
If the press were mounted with the ram on bottom so the die is moving upwards would make a cart easy to build, but for some reason that just seems awkward. Coal Iron says the press can be mounted either way. Comments?
