I found making the tools was just as fun making a knife.Something that needs to be mentioned in the thread is the fun of building one's own grinder, it really is an enjoyable task.
That is a SUPER NICE pen. Please tell me what is the material and what tools used to make it?Did somebody say pens?? Couldn't resist....
Hobby or Pro, being as diverse as possible in your offerings can mean the difference between success and failure. I started building pens like this to give to customer who purchased high end knives, as a thank you gift. They quickly took on a life of their own, and have been a core source of income ever since.
On day I would like to know how you make damascus tubes. I sure hope it is not by drilling a rod out on a lathe...Did somebody say pens?? Couldn't resist....
You nailed it....that is exactly how it's done. It works out to about a 50% material waste of Damascus.... but by using the kit parts, and charging what I do, I can still make it worth my efforts.On day I would like to know how you make damascus tubes. I sure hope it is not by drilling a rod out on a lathe...
Getting a homebuilt grinder in alignment isn't a problem "IF" you use the correct design. The only thing that is critical on alignment is the tracking and platen/contact wheels. Motor alignment can be handled in one of two ways, either use the motor alignment as the tracking adjustment, or using a fixed motor mount as in the 56C motor type mount. These plans are about the best around (free of course) and assure everything will be aligned properly. https://tinyurl.com/y3v8fgvsThanks everyone for the different perspectives. Someone earlier had mentioned that building his own sander/grinder caused him much grief and time aligning the wheels to track correctly. That comment really caught my attention. I really do enjoy building things but if alignment is going to be an issue, that will kill my enthusiasm to build my own even though I very likely have all the tools needed to do so. I have the commercial band saw, mig, tig, plasma cutter, etc..
Since I do not have a lathe I figured that was how it is done.You nailed it....that is exactly how it's done. It works out to about a 50% material waste of Damascus.... but by using the kit parts, and charging what I do, I can still make it worth my efforts.
Thanks everyone for the different perspectives. Someone earlier had mentioned that building his own sander/grinder caused him much grief and time aligning the wheels to track correctly. That comment really caught my attention. I really do enjoy building things but if alignment is going to be an issue, that will kill my enthusiasm to build my own even though I very likely have all the tools needed to do so. I have the commercial band saw, mig, tig, plasma cutter, etc.. But I have run into issues with various projects where alignment became an issue and a BIG ISSUE. Mucho time was spent trying to correct it, sometimes it worked, sometimes not. So as of now, I'm leaning to buying already made.
Pen turning/making: I actually have the lathe and wood blanks (walnut, maple, mahogany, oak, etc.) to do this, just don't have the time to do it. It's one of my bucket list items once I get into retirement.
Exactly what I was thinking. Alignment was never an issue for me either. It may have been another issue rather then a tracking issue. One of the very best benefits from building one's own grinder is that they are easy to modify, upgrade and/or fix if the need or want arises.I built my own and didn't have any alignment issues. The NWG has a tracking adjustment that works well and is about as simple as it gets.
Nwg was what I built following the plans and had immense issues... Funny how doing the same thing by two different people can yield such different results!I built my own and didn't have any alignment issues. The NWG has a tracking adjustment that works well and is about as simple as it gets.
Thank you Ken. This is what I have been looking for. A build along with plans n stuff - this is awesome.Getting a homebuilt grinder in alignment isn't a problem "IF" you use the correct design. The only thing that is critical on alignment is the tracking and platen/contact wheels. Motor alignment can be handled in one of two ways, either use the motor alignment as the tracking adjustment, or using a fixed motor mount as in the 56C motor type mount. These plans are about the best around (free of course) and assure everything will be aligned properly. https://tinyurl.com/y3v8fgvs
There is a link in first post for a "build-along" and plans are in a PDF format. If you purchase everything to build the grinder you'll have $700-$800 or so (for sure less than a $1,000) invested (using a cheap Chinese VFD) that will rival any of the "high dollar" commercial grinders around.
Now, as to the economical aspect of building your own grinder, it depends on how valuable your time is. If, like Ed your income depends on turning out product then time becomes valuable. Like me, as a hobbyist who enjoys building, knives, guns, tools, etc building my own grinder is well worthwhile.
The old Craftsman lathes are good and are available on Craigslist fairly often.Ed, if a guy was looking to buy a decent metal lathe for turning nothing bigger than pens, do you have a recommendation?
You would make killer pens John.Ed, if a guy was looking to buy a decent metal lathe for turning nothing bigger than pens, do you have a recommendation?
Can you even imagine?You would make killer pens John.
