Authentic Filipino Balisong Butterfly Knives: What to Look For Before You Buy
Start with the pivot and overall fit​
On a traditional Batangas-style balisong, the pivot and blade fit tell you quite a bit about the knife. A properly fitted pivot should allow smooth movement without making the blade feel loose or sloppy.​
It is also worth checking how the handles move relative to each other. Excessive side-to-side play, uneven movement or a blade that does not sit properly when closed are usually signs that the knife needs more attention.
Steel depends on how you plan to use it​
There is no single "best" steel for every balisong.
D2 is a popular choice when edge retention and toughness are priorities. VG10 makes more sense for someone who wants a stainless steel option with good edge retention and easier corrosion resistance.
For collectors, pattern-welded Damascus can add something completely different, especially when the blade pattern and handle materials are part of the appeal.
Do not overlook the handles​
The handles should feel balanced in the hand rather than simply looking good in photographs. Pay attention to the latch, handle alignment, weight and how naturally the knife opens and closes.​
Traditional balisongs can also have quite a bit of variation because many are made with hands-on fitting rather than coming from an identical factory production line. Small differences are not automatically a problem. What matters is whether the knife feels properly assembled and consistent in operation.
Look at the maker, not just the pattern​
One thing I would recommend to anyone shopping for a Filipino balisong is to learn a little about who actually made the knife.
Ask where it was made, what steel was used, how the handles were constructed and whether the seller can explain the knife beyond simply calling it a "Filipino balisong."
That information can tell you much more than a product description full of marketing terms.
For anyone interested in the history behind the tradition, we also put together a short overview of the history of the balisong and its Filipino roots:
https://balisongbutterfly.com/history-of-the-balisong
And if you want to see an example of the traditional style, the Bagyo Karambit Balisong is one of the pieces in our collection:
https://balisongbutterfly.com/product/hand-forged-d2-steel-balisong-snake-blade-bf-149
I am happy to answer questions about steel, construction, Filipino balisong history or what to look for when comparing different makers. I think the more information people have before buying, the easier it is to find a knife that actually suits what they want to do with it.
