Casey Brown
So, I've really liked the looks of some of the wrought iron guards that I have seen some people use. It looks really cool when etched. However, here's my question. Do you re-forge the wrought iron before you use it for your guard. I cut a piece and started slotting it for a guard, and noticed after a lot of work, that the piece had a crack running down the middle of the piece I cut. Due to the fibrous nature of the wrought iron, I'm assuming this could always be and issue on really old pieces. Do I try to basically do a quick forge weld of the piece to make sure that it is solid, before I try using it as a guard?
