Erin Burke
PHOTO #87
I am a big fan of printing "to-scale" templates for my guards, spacers, etc.
this ensures that -- to the best of my ability -- the fittings are symmetrical. It also gives me a chance to visualize them before I start grinding. At home, I have an older version of AutoCAD... while at work, I've been known to create templates in Microstation. (Note: I also rely heavily on CAD anytime I build a folder.)
I use some fairly coarse-grit belts (probably slightly used blue zirc 36-grit) to grind close to the lines, then follow up with cheap 120-grit AO.
PHOTO #88
Rounding/breaking the hard edge on the seppa, foo'. Straight-up KMG action fo' shizzle.
Following up the 220-grit AO with a A30 trizact gives me silky-soft fingertips... with the added benefit of removing my prints, helping me avoid positive identification in the NSA's database.
PHOTO #89
Grinding things... making them square. Working Title: The Many and Diverse Uses of Aluminum Angle
It's important, when truing up a block on the grinder, that the platen is square to the table, and the fence is square to the platen.
PHOTO #90
Here are all three fittings ground to shape. It's all hand-filing and decoration from this point forward.
On most multi-level guards -- or guards/ferrules with multiple spacers -- I will use alignment pins. On this knife however, the seppa and guard are fitted exactly to the blade, and the ferrule is one piece (with at snug fit) and offset from from the guard in both side (profile) and top views... so I found them unnecessary.
PHOTO #91
A little blue Dykem, some simple math, and a height gauge give us some target lines for filing in the grooves. As I work, the Dykem can sometimes start to rub off... but because I wrote down all of the height gauge measurements, I can re-mark as necessary.
As shown on the original sketch, I'm looking for three deep grooves in the ferrule with thin flats in between and adjacent to the guard and handle. I'd like all the grooves and flats to be consistent. The guard will get one groove around the perimeter.
PHOTO #92
Here I am using a diamond wheel on the mill to create a "starter groove" for the hand filing. It just helps act as a guide for my first small round file.
The work-piece is set on the flat of my milling vise, and slid against the wheel by hand. Sometimes it can be tricky to make clean transitions at the corners, especially as the rotating wheel approaches a leading edge... so I like to run the mill in both directions. Not sure if this makes sense.
PHOTO #93
Self-explanitory
Trivia Question: What is the tool most likely to draw blood in my shop?...
Answer: ...that would be the file card. Draining me dry, one diabetes-test sized hole at a time.
PHOTO #94
Magnifying head-gear from Harbor Freight... useful for filework and picking up chicks.
Working on the ferrule here.
PHOTO #95
Cleaning up with P800 wrapped around an appropriately-sized transfer punch... and held tight with a small spring clamp. Will probably go to about P2000.
There's probably a faster way to do this, but I haven't figured it out yet.
PHOTO #88
PHOTO #89
PHOTO #90
PHOTO #91
PHOTO #92
PHOTO #93
Self-explanitory
PHOTO #94
PHOTO #95
