Dan Graves
I can get this flywheel press. Am trying to find out if it will work for making Damascus. They told me it is used as a punch. That you set the hieght and it goes to that height hell or high water. Here are the spec's on it and some pictures. Can it be modified or is there a way to work with it? The foot control just makes it do its punch or press at one height and 30 tons of pressure. Can it be modified to have control on the amount of pressure?
30 TON PRESS-RITE O.B.I. PUNCH PRESSModel No. 30; Air clutch & brake; Flywheel type
Stroke: 2-1/2"
Slide adjustment: 1-3/4"
Shut height S.D.A.U.: 10" to top of bed
Area of bed: 24" L-R x 14" F-B
Bolster thickness: 2"
Area of slide: 10" L-R x 8" F-B
Shank hole diameter: 2"
Throat depth: 7-1/2"
Opening through back: 11"
Floor to top of bed: 31"
S.P.M. approx.: 120
EQUIPPED WITH: Dual palm buttons for run with
emergency stop button
Electric foot switch
Pushbuttons for start-stop &
top stop button
Selector switches for inch-single-
continuous-hand & foot
Inclining mechanism
Knockout slot in slide
Production counter
3 HP 1145 RPM 220/440/3/60 Motor
Weight approx. 3500#
Overall dimensions approx. 55" L-R x 48" F-B x 80" H
Serial No. 2497
Stock No. 23633
Stroke: 2-1/2"
S.P.M. approx.: 120
top stop button
Inclining mechanism
Production counter
Serial No. 2497
Stock No. 23633
