Dan Youngs
Active Member
I am wondering what size you drill your holes for handle pins. I am using 1/8' and 3/16" pins, I was drill the small size holes but yesterday I cracked a scale. Does the epoxy expand when it dries? I did not see any sign of a crack until after the epoxy dried. Should I drill a slightly larger hole?
The scale was Brazilian hard wood. the pins were brass. I also laminated a brass sheet on each side of the blade. The whole thing was pretty tight going together.
The crack is centered in two of the pins.
