I will not recommend to do as I do, but I have a 22.5 Evenheat oven, 220V. It must have around 2, to 2 1/2 hours to cool down to below 250F with the door open, which is not good for the elements, but I do it anyway. I crack it open for maybe 30 minutes, then open it wide open. After it drops that low in temp, I re-program for the first temper and re-start it. It will go as much as 25° over temp, but then back off and settle in. Then I put the blades in. As far as carbon blades go, I use that AST, or ATP, or whatever it is that you paint on. Works great for me. No appreciable de-carb, and it comes off in the quench, which I'm sure I'll have to filter out one day. I use a lot of 01, and have never had it crack in quench, or while the oven cooled down, but as I said, I will not recommend what I do. You will have to decide that for yourself. The way I see it, is, if I have to buy elements every 4 or 5 years, so be it. This oven has been going over 3 years now with no problems. If you are going to use a high carbon 10XX steel, or similar, you could give it a snap temper in your kitchen range while the oven cools.
