Yep, those are my pictures of the surface grinder. I was off line for a while trying to get my meds right and recovering from an offstate condition and did not see the posts asking about the surface grinder. I put the surface grinder on a stand with a PM motor and PM controller. I also made the stand so I could slide the grinder in or out so I could use both 2.5" X 48" belts or 2.5" X 72" belts. Phoneix Abrasives makes the 2.5" wide belts for me in varying grits. The mag chuck cannot be turned on and off like the regular surface grinders. You just pull the blade off, clean the chuck, and flip the blade to its other side. No, the grinder will not dislodge the blade and sling it at you. For accuracy test, I used a blank for a 4" folder, made sure I had it flat by checking it on the surface plate. I put the blank on the surface grinder, put on a 220 used belt that still had some bite to it. Started grinding one side and quit when the grit marks were uniform. Flipped the blade, started grinding, and completed grind. I took the blank off, de-maged it, and checked thickness of the blank. Checked every half inch all the way around the blank, and from starting out at about .1362, I ended up with .1315". Was it close? Yep. It was the same all the way around with no variations over .0005 (5 ten thousandths). Since then I have used it several times and it has always given the same results. I don't run it fast because you do not need to. Considering the cost of PM motor and PM controller, I have $2100 in it. But, this is a versatile grinder. I can take the surface grinder off and put a horizontal small wheel attachment on it that has wheels to fit that measure from .500" up through .750", 1.00", 2.00", and 3.00". I can putt a 9" disc on it, also. Every attachment can use either the 48" belts or the 72" belts. So from that point it is several grinders in one.
