Originally designed this as an "off trail" knife. The 20 lpi "file" and the flat at the back were designed to work with magnesium blocks or swedish fire steels...and they do that well. The file does a good job in notching bows or snare triggers etc.
This one is slightly modified based on some input I had from a medic who carried one over in Irag. The blade is a bit more pointy and the file is raised slightly above the spine to give better purchase. Blade is 4 1/4" , is 3/32", and is ground from CPM154CM. Handle is normally hunter orange or yellow but I thought I'd give this style G-10 a try for high contrast. Needs a sheath.
