cardoso5fr
Folded stainless handle and XC75 oil differential hardened blade.
I intend to make a clip on that one, but i broked my taps in the hole... Don't succeed to put away the broken piece. I Tappered two other hole and failed first , second and third clip...... I was a bit ........, i drilled a lot of hole in the handle and toxified everything in order to calm my nerves.....
The various clip have fled in the workshop.
13 cm close heel to the tail, 2,3 cm de high. 17,6 cm long, 7,2 cm de sharp. 3 mm thick (blade) , 6 mm full thicknes without screw.
