Well, spend $80 for the cheap Chinese VFD to use while saving funds for the KBEC-27...... you might be surprised how many years it would last. https://www.ebay.com/itm/232756241295?
Dumb question but will this VFD you linked work with a 1.5 hp motor?
When the non NEMA 4 VFDs are in close approximation to a belt grinder lots of fine metal grindings are sucked into the VFD causing it to short out . With a mill and surface grinder fluids are used to cool the tool so any grindings don't get airborne so much.
Daniel...not seeing the problem? It looks like plenty of room to add holes to the base...but also looks like the existing ones will work?
Hi Guys.....I'm also putting together a 2x72 and looking for a motor. Where are you fellas buying the IronHorse motors from?
thanks......Jeff
Ok guys I have a question about wiring this motor. Got everything figured out but I don't see a grounding wire. Including some pics. Do you guys see one? I don't see any green wire? I know the end of the wires look rough they came like that. I'll trim em back a bit. View attachment 63864View attachment 63865View attachment 63866
