rhinoknives
I am going to post it right here! Can anyone think of a better place to do it? I figured I would just continue
on this same thread.
WORK IN PROGRESS, On Aarons knife.
I start with a blank I have had water
jet cut out of 1/8" 440C Stainless. The blade is 1" tall at the ricassio or where the Plunge line will be.
I have Picked out a nice block of Bocote wood, Stabilized by "Faron Moore"
for the scales and some yellow fiber board for the liners along with two Bob Loveless type bolts that are also stainless. For me in the kitchen I want all stainless steels whenever possible.
After clean up and drilling the holes the blank is then H-ted by
Paul Bos Heat treat by Buck Knives to a RC of 59 points.
Next it is time to use my Bruce Bump File guide that was the first Stainless one made out of his shop!:biggrin:
This 5" Paring/Utility with be more in the Japanese Petty Knife style vs the 3" Paring knife I started the contest with.
I do a full vee flat grind all the way to the spine so there is no resistant wedge at the top like can happen with hollow grinding a blade like this. I will also distal taper the blade starting at just a tad under the 1/8" thickness of the steel down to as thin as I can get the tip..
I should have time to grind out this blade tomorrow so I will add a picture and comments after that's done.
Thanks everyone!
Laurence
www.rhinoknives.com
Here is the next set of steps I take when making one of my 5" Petty knives.
The handle and ricasso area are cleaned up on a 120 Grit MSA belt on the flat platen of my Hardcore Products 1 1/2hp variable speed grinder. I run 120 and finer grit belts at no more than 25-30% on the dial.
Every belt has a sweet speed where I feel the best balance of cleaning and finish.
Then it's time to tighten down my Bruce Bump File guide. I have a slight angle from the top of the thumb ramp to the bottom of the Ricasso were I start the plunge line grind.
And now it's to the grinder for a full vee grind on both sides, I don't mark off my center lines. I did it a few times when I started in 1996 and have just ground my center by eyeball ever since.
It may not be the fastest or most exact but it has worked for me.
I use MSA ceramic belts in a 36grit belt and do 90% of the grinding I want, Then it's to a 50 grit, Then I finish up my last 5% with a 120 grit. After that I use cork belts at 220 - 600 grit depending on the finish I am after. For culinary I like a brush satin look and this seems to cover scratches etc the best. Also a mirror finish can make food even more likely to stick so there is a practical reason for my choice of this finish.
I go for about a 1/3 to 1/2 the thickness of a new penny for my knives. on this one I am at a 1/3rd.
The last picture shows us all taped up and ready for some handle work!
Questions and comments are always welcome.
Thanks for watching.
Laurence
www.rhinoknives.com
