Like butter huh? I just spent over an hour more on this darn hook and it's still not good. Probably the last one I'll make. I used a chain saw file to make the bevel shallower using a sharpy marker to see when I got to the edge and the the dremel stone polish it. Sandpaper on a rod also. I have a 3/8" stone coming. if that doesn't do it I'm stumped.Once I got the gut hook formed with a file, I chucked up a ceramic rod in the drill press, wrapped and taped 400 grit sand paper around it. After running this and getting it close, I used just the ceramic rod. It cut through deer hide like butter!
UncleBilly
Sorry guys hold on . Gut hooks are a very difficult edge to sharpen YES EDGE . you arnt sharpeninga long blade but a curved hook shaped edge. This is the way ive found works better than anything ive seen or been told . You need a fairly large file I like a 3/8 or 1/2 inch round file to shape and start things and keep it even . I then move to the sand paper wraped around the file start at 220 and go to 600 then I use a dremel tool with creytex bullets in fine and extra fine in the 1/4 inch and bigger sizes . I get excellent results and never get complaints from my customers . To just sharpen the gut hook takes me 3 to 4 min . Keep it even and its always perfect. Some makers use a wedge or should I say single beveled edge for all of their gut hooks.
Scott, that's exactly how I do it and have tried with and without buffing compound. The fine cretex wheels leave pretty much a mirror polish anyway.
I've seen some so bad that I took a carbide cutter and reworked it and worked my way down to the cretex.
That method is for making the guthook work but to really improve the knife use a good 50 or 60 grit on your grinder and the grind the gut hook off of the knife.
I see mostly ground on both sides Scott but then I don't go out of my way to look at them. And Yeh, they do hang on everything. They are useful for the part of field dressing that takes a total of about 5-10 seconds with a good drop point and are a hindrance the rest of the time. It's not worth it to me to save a couple seconds when unzipping one.
On the plus side they are handy for hanging your knife on a limb to keep from loosing it and they can be very handy opening a bottle of pop but you don't see those type bottles much any more.
