jmforge
What grind lines are you talking about? I don't do scandi, saber, etc grind so the only lines that I typically have on a blade are the plunges and swedges, so this may not be a problem for me.I use the surface conditioning on hollow ground and it can wash out the grind lines if you let it get close. I put lotsa blue tape along the grind line and am very careful not to let it get on that line. I'll hand sand at the bevel line at least it cuts down on the hand sanding.
Everyone is right, they won't take out deep scratches but I see that as a good thing. It "points them out" to me and then I go back with a 1000 grit norax belt and fix those. The norax belts are nice as you can get the high grits but without the annoying "bump" from the seam.
